Date/Time: Mon, 29 Apr 2024 01:31:19 +0000
Continuous contract
View Count: 1063
[2013-12-13 07:42:06] |
golan_82 - Posts: 24 |
Hi , I have some problem to see properly the 6E continuous. I'm using open e cry data feed. I the daily chart I use continuous contract but the current price doesn't upgrade as the price really moves online. what should I put in the chart settings at the "symbol" and in the "trade and current quote". for now in the "symbol" I use E6# but it makes problem , what should I put there that I can also see the history properly and also the current price online thanks |
[2013-12-13 20:58:03] |
This is explained here: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html#Symbol_Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
