Date/Time: Sat, 11 May 2024 17:09:37 +0000
How to use Input Data in Alert condition when there is no Subgraph
View Count: 625
[2019-09-25 12:57:04] |
User613910 - Posts: 45 |
Hi, I want to make an alert when In:85 (from the NumbersBars ID:15) is > 0 and In:87 < 0 Can you please help? I can not find how to deal with this information in a alert. See also attached picture, Already thanks, Anita |
tempsnip.png / V - Attached On 2019-09-25 12:56:13 UTC - Size: 58.45 KB - 226 views |
[2019-09-25 13:55:16] |
There currently is no way to access Input values in Alert Condition formulas. We will see about adding that capability.
[2019-09-26 07:03:54] |
Hi, thanks for your answer but it suprises me that I can not use this data for a alert. Is there a way to transform this data into a Subgraph? Already thanks, Anita |
[2019-10-01 10:30:02] |
Yes by using a custom study: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
