Date/Time: Sat, 18 May 2024 05:59:21 +0000
the trading volume of the symbol is accumulated and when it meets or exceeds the set vol
View Count: 463
[2019-09-24 14:16:02] |
euroventure - Posts: 2 |
the trading volume of the symbol is accumulated and when it meets or exceeds the set Volume for the order, then the order is submitted as a Limit order, the above is a description of a stop limit volume trigger order, how is the trading volume accumulation calculated |
[2019-09-24 15:12:19] |
It is nothing more than a simple sum of the volume of the trades as they occur.
