Date/Time: Fri, 03 May 2024 21:33:40 +0000
VbP Setting
View Count: 1445
[2013-12-12 22:34:17] |
infpz - Posts: 826 |
Is there a way to tweak Sierra chart and have the VbP showing like this GOMI in the file attached? The colors tell the volume strength. Blue is light, green more volume, amber even more and so on. -PZ |
[2013-12-13 01:14:55] |
This type of color coding is not supported. Only color coding for the following: Bid Volume Ask Volume Point of Control Value Area However, when using the Numbers Bars study, there is greater control over the volume profiles that display for each bar: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-13 01:16:19
