Date/Time: Mon, 06 May 2024 16:50:15 +0000
mg
View Count: 1145
[2013-12-12 20:20:51] |
MARTIN G JONES - Posts: 1 |
My charts are not updating
[2013-12-12 20:37:14] |
We see you are using the "SC Historical Data" Service. With this particular service, the charts will not continuously update. You could do a manual update by reconnecting to the data feed using the Disconnect and Connect commands on the File menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
