Date/Time: Sun, 05 May 2024 07:09:34 +0000
rollover contracts
View Count: 1070
[2013-12-12 18:18:38] |
russellg - Posts: 8 |
I TRADE THE NQ'S AND THE YM'S. I NEED TO ROLLOVER THE CONTRACTS TO THE NEXT EXP DATE. I CURRENTLY USE TICK CHARTS AND NEED TO KNOW WHAT THE BEST WAY TO ROLL OVER IS . I TRIED USING THE "PERFORM FUTURES SYMBOL ROLLOVER TAB, BUT MY CHARTS ARE SO SCREWED UP, THE DATA IS UNUSABLE.
[2013-12-12 20:41:28] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?l=doc/doc_ChangingFuturesContract.html Basically you need to change the symbol of the chart and if there is any problem with the chart data, go to the chart and select Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-12 20:41:44
