Date/Time: Sat, 18 May 2024 20:20:04 +0000
Difference between specific stocks and stocks
View Count: 548
[2019-09-19 11:51:28] |
sugart - Posts: 25 |
Hi, What is the difference between the symbols of "Specific Stocks" and "Stocks" in Chart settings=> Symbol=> Find? For example, when I backtest the same strategy using the symbols MSFT-STK-SMART/NASDAQ and MSFT, I get different results. Thanks. |
[2019-09-19 23:24:37] |
The category Stocks list no symbols. So that is just not relevant. The best solution is to use this data feed: Sierra Chart Exchange Data Feed For now follow the instructions here: Interactive Brokers Trading Service: Using Sierra Chart Historical Data And be sure to fully re-download the data in both of those charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
