Date/Time: Sat, 18 May 2024 22:27:00 +0000
More than one calculated value on the High of a bar
View Count: 511
[2019-09-19 08:32:02] |
User787778 - Posts: 139 |
Is it possible to have 3 calculated values placed above the high of a bar of the main price graph in chart region one? Say one value at 5 ticks above the bar high, value two a at 10 ticks above the bar high and value three at 15 ticks above the bar high.
[2019-09-19 08:34:32] |
All of this is possible, however the question we have is what study are you using to accomplish this?
[2019-09-19 09:27:27] |
I would like to use 6 calculated values (3 shown on top of the bar high and 3 shown below the bar low) from either from a spreadsheet study or 6 different spreadsheet formula studies.
[2019-09-20 08:45:32] |
Have a look at using multiple instances of this study: Study Subgraph Above/Below Bar as Text The study Subgraphs that it references will then need to have their Draw Style set to Ignore. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
