Date/Time: Mon, 29 Apr 2024 14:12:16 +0000
hollow cadlesticks
View Count: 2757
[2013-04-11 14:47:20] |
User95628 - Posts: 7 |
How do I make hollow candlestick bars? I would like the outline to be red or green but the inside hollow. It saves a tremendous amount of ink when printing.
[2013-04-11 17:36:01] |
M5amhan - Posts: 468 |
try going to global settings>graphics settings then change candlestick up fill and candlestick down fill to the same color as your background
[2013-04-11 17:39:03] |
Thanks but it doesn't change it.
[2013-04-11 17:41:02] |
k do this for each chart you want to change click the chart go to chart tab>graphics settings check use global graphics settings instead of these settings OR you can just change the candlestick up/down fill from this menu for each chart Date Time Of Last Edit: 2013-04-11 17:41:43
[2013-04-11 17:42:23] |
great. it worked thanks a lot.
[2013-04-11 17:46:25] |
how do you do the same thing with renko boxes?
[2013-04-11 17:50:02] |
the same way either do it by checking the box from the graphics menu in the chart tab, or change candlestick fill in the menu from the chart tab you have to click the chart before clicking the chart tab |
[2013-04-11 17:50:39] |
For reference, here is the documentation to change Candlestick colors: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Renko bars are candlesticks. Therefore the candlestick color settings do affect Renko bars. We verified this just now. Unless you happen to be using one of the older Renko studies. In that case, the settings through the study itself affect the colors. You really should be using the new Renko in Ticks setting: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#RenkoInTicks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-11 18:11:54] |
It's not working with the renko chart.
[2013-04-11 18:21:16] |
it should unless you are using the renko as the study rather than the chart setting. like the support said, you should be using the chart setting. go to chart settings>bar period:renko in ticks or flex renko either one should work delete the study renko Date Time Of Last Edit: 2013-04-11 18:21:28
[2013-04-11 18:52:18] |
awesome.thanks.
