Date/Time: Sun, 19 May 2024 03:48:17 +0000
CQG FIX
View Count: 833
[2019-09-18 22:10:08] |
User725605 - Posts: 60 |
Hello. I received a request upon booting up Sierra to sign a CQG PDF I accepted, sent and closed. When I go to boot up my Sierra I receive an error message popup that states - "Sierra Connect Error, 20 Login Attempts in 5 minutes." I cannot connect to the data feed. Please advise. |
[2019-09-19 04:28:28] |
The pop-up message would not state "Sierra". It would only be referring to CQG. The error message is from CQG. It is CQG blocking the connection. Disconnect with File >> Disconnect . Wait greater than 5 minutes and connect again. For further help, refer to: CQG Trading Platform Service: Common Error Messages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 04:29:58
