Date/Time: Sun, 19 May 2024 07:45:06 +0000
[User Discussion] - Buy-stop / Buy-stop-limit fill quick as market order
View Count: 1240
[2019-09-18 20:51:15] |
asetnes83 - Posts: 21 |
I am trying to place a buy stop order above current price (long entry) and it is filling automatically. Why is this?
screenshot1.png / V - Attached On 2019-09-18 20:50:32 UTC - Size: 121.02 KB - 290 views screenshot2.png / V - Attached On 2019-09-18 20:50:40 UTC - Size: 102.75 KB - 257 views |
[2019-09-19 07:24:35] |
Keep in mind that if you left or right click in the order columns on the Trading DOM, that sends an order based on your settings in Trade >> Chart DOM Settings. Not what is selected on the Trade Window at that time. Refer to the following: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 07:25:09
[2019-09-19 12:38:28] |
I'm missing that option from the menu. I do not see Chart DOM Settings.
[2019-09-19 23:17:02] |
Because you are a Transact user, you probably will need to update to the latest version of Sierra Chart: Software Download: Fast Update But understand that Live trading with Transact is not yet available in the latest version. It should be we hope next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
