Date/Time: Sun, 19 May 2024 06:24:37 +0000
Function GetTotalNetProfitLossForAllSymbols does not update during a chart replay
View Count: 548
[2019-09-18 20:50:26] |
@sstfrederik - Posts: 404 |
Hi, Function GetTotalNetProfitLossForAllSymbols does not update during a replay. The Chart Stats on the trade activity log show the correct value. When I stop the replay the value from the function is shown correctly. sc.MaintainTradeStatisticsAndTradesData = 1; Am I missing some kind of setting or does this function not work in replay mode? Thanks, Frederik |
[2019-09-19 03:57:53] |
This could be the case and it is definitely not something we can spend any time on. Therefore, do not use the function.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 03:58:37
