Date/Time: Sun, 19 May 2024 02:02:07 +0000
Murrey Math Setting
View Count: 1441
[2019-09-18 12:56:31] |
Terry Ko - Posts: 21 |
Hi, I have a question about Murrey Math setting. How can I setting a time? the time period as below: Daily Bar Open (evening time open) 17:15 Evening time close 03:00 Morning time open 09:15 Daily Bar Close 16:30 I had try to setting, but the Murrey Math Line never update a line on 17:15 everyday. thanks. |
[2019-09-18 19:30:43] |
Refer to the documentation for this study. The lines are drawn based on the size of the square that you set, which is also based on the last bar you set to use to determine the lines. Murrey Math Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
