Date/Time: Tue, 07 May 2024 13:17:38 +0000
MarkedDepth is not recorded in the system
View Count: 509
[2019-09-18 12:27:27] |
AndreyPoroshin - Posts: 102 |
Hello. I noticed that MarkedDepth is not recorded in the system, although the function is enabled in the settings. What could be the problem? Last record was on 09/11/2019 I attach screenshots to the message Date Time Of Last Edit: 2019-09-18 12:29:19
DEPTH rec.png / V - Attached On 2019-09-18 12:26:45 UTC - Size: 99.18 KB - 279 views |
[2019-09-18 13:07:02] |
You need to enable Global Settings >> Symbol Settings >> Use Custom Symbol Settings Values .
