Date/Time: Mon, 29 Apr 2024 04:46:47 +0000
VbP Volume By Price study - 1 profile per bar, with each profile based on X bars
View Count: 519
[2019-09-18 12:07:38] |
ochocinco - Posts: 29 |
Hi, can the Volume By Price study display per each bar, yet be based on the last X number of bar's data? Example where X = 3. draw a profile on bar #3, based on data of bars 1-3, draw a profile on bar #4 based on the data of bars 2-4, and so on. For lack of a better term I'm asking if a rolling VbP study is possible using its native settings or some combination of studies. thanks! |
[2019-09-19 04:40:52] |
No, this is not supported.
