Date/Time: Sat, 27 Apr 2024 05:49:16 +0000
Shell Oil Symbol RDSa, etc. will not chart on stock entry
View Count: 1633
[2013-12-12 16:39:25] |
User73463 - Posts: 21 |
What is the symbol for Shell Oil. None of the correct stock entries will work. I need the major symbol. Thanks.
[2013-12-12 21:00:55] |
If you are interested in the NYSE symbol, refer to this page: https://www.sierrachart.com/index.php?l=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=5#NYSE Apparently it is one of the Royal Dutch Shell symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-13 00:03:19] |
TastyRisk - Posts: 119 |
Major symbol is on the LSE (price would be GBX -not pounds or dollars). You can get free quotes from alternate venues. Check in TWS for the other exchanges when you select the symbol.
Date Time Of Last Edit: 2013-12-13 00:04:53
