Date/Time: Sat, 27 Apr 2024 21:27:33 +0000
Login problem?
View Count: 1612
[2013-12-12 16:04:53] |
Luke - Posts: 142 |
Hi, I am currently trading through Mirus Futures (Zenfire/Ninjatrader) and use Sierrachart/Iqfeed for Charting only. My question is: Can I use the new Sierrachart real-time Futures data feed instead of Iqfeed for Charting and continue using Zenfire/Ninjatrader for order execution at the same time? Or would there be the problem of a double login? (the way I understand it, I need to login to my supported Trading service (Zenfire), in order to use the Sierra Futures data feed, which would probably mean I wouldn´t be able to connect to Zenfire/Ninjatrader for order execution at the same time, right??
[2013-12-12 17:27:06] |
In order to take advantage of the CME exchange fee waiver, it is necessary for Sierra Chart to connect to your Zen-Fire account, which it can do. There is no concern with that. You do not have to trade through Sierra Chart, but you can get the data. You need to contact your broker and ask them to allow 2 logins to your account. They should be able to do that. Have a look at Sierra Chart trading functionality. It is quite good. Here is our main documentation page for: http://www.sierrachart.com/index.php?l=doc/doc_Trading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
