Date/Time: Wed, 01 May 2024 06:34:56 +0000
SC Tom DeMark: Trading the Nines?
View Count: 10347
[2020-06-09 07:49:19] |
Eric - Posts: 21 |
Hi, I have followed the given instructions. I duplicated a new chartbook but for some reason it is not in the data folder. I uploaded the original cht file instead. As what you suggested, I've removed everything with only the TD study left. This is a 50 point range bar for HSI futures. Everything's removed but as you see, the numbers can get up to 1000s. Eric |
studies.jpg / V - Attached On 2020-06-09 07:46:24 UTC - Size: 138.05 KB - 505 views ChartbookExample.cht - Attached On 2020-06-09 07:46:51 UTC - Size: 20.65 KB - 322 views |
[2020-06-10 19:15:57] |
John - SC Support - Posts: 31240 |
The chartbook you attached does not have the chart you show in the images and does not have the Trading the Nines study on it. We are unable to reproduce the issue you are having with the study and a range chart. Even for the same symbol (HSM20). Therefore, we really need that Chartbook with the chart so we can see if there is something about your setup that is creating this.
[2024-04-20 02:59:45] |
User14953 - Posts: 190 |
Can the Tick Offset in the Trading the Nines Study be configured based on percentage?
Date Time Of Last Edit: 2024-04-20 03:00:49
[2024-04-21 00:00:21] |
You happened to catch us at a very good time, so we have added this option. Refer to the information for the Inputs at the following link for how it works: Trading the Nines: Inputs This change will be in the next Pre-Release (v 2630). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
