Date/Time: Wed, 01 May 2024 09:10:49 +0000
SC Tom DeMark: Trading the Nines?
View Count: 10348
[2019-09-16 18:42:13] |
User14953 - Posts: 190 |
Does Sierra Chart have a study for Tom DeMark: Trading the Nines? Thx https://www.youtube.com/watch?v=h5PuTzDimNA |
[2019-09-17 14:23:27] |
John - SC Support - Posts: 31240 |
Take a look at the following 2 studies and see if they are what you are looking for, as these are based on Tom DeMark's work: DeMarker Oscillator Type I DeMarker Oscillator Type II For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-17 16:34:30] |
No, those do not appear to be it. A DeMark 9-Count Setup consists of the following: _A series of nine consecutive bars that close higher or lower than the close 4 bars earlier. _9 consecutive closes “higher” than the close 4 bars prior is a “sell setup” and 9 consecutive closes “lower” than the close 4 bars prior is a “buy setup.” _Numbers 1 through 9 are placed above each qualifying bar's highs, or below each qualifying bar's lows. Perfected setups _A “sell setup” is “perfected” when the the high of bars 6 and 7 in the count are exceeded by the high of bars 8 or 9, reverse = “buy setup”. https://www.seeitmarket.com/understanding-the-basics-of-demark-setups/ Understanding the Basics of DeMark Setups https://www.youtube.com/watch?v=h5PuTzDimNA Tom DeMark: Trading the Nines Date Time Of Last Edit: 2019-09-17 16:35:27
[2019-09-18 19:03:31] |
SC Support Tom - Posts: 450 |
Hello, I am in the process of adding all of the DeMark indicators since they are so frequently asked for. I am working from his two books New Market Timing Techniques and The New Science of Technical Analysis. I believe that this is close to what he calls "TD Sequential", which I have not yet worked on. I will have to carefully check to be sure. Also in the video that you posted he mentions that he is discussing something that is not in the book, so I will need to study what he is saying here so that I can integrate the new information with what is in the book.
Date Time Of Last Edit: 2019-09-18 19:03:54
[2019-09-18 21:48:51] |
seandunaway - Posts: 213 |
Thank you Tom! Impressive, SC team, impressive. |
[2019-09-19 10:41:58] |
john4th - Posts: 23 |
Tom, Mr DeMark also gave his blessing to another book: DeMark Indicators ISBN: 9781576603147 |
[2019-09-20 15:38:13] |
Tom, I have a detailed explanation about most of the DeMark Indicators. Would you like me to send you the information? |
[2019-09-20 16:38:04] |
Mr DeMark also gave his blessing to another book: DeMark Indicators ISBN: 9781576603147 If it that is the one by Jason Perl with foreword written by DeMark, then I have that one too. I have a detailed explanation about most of the DeMark Indicators. Would you like me to send you the information? Sure, thanks! |
[2019-09-20 16:45:48] |
Please let me know how to send you the detailed explanations
[2019-09-20 16:46:49] |
Hi, you can send them to Tom@sierrachart.com. Thanks!
[2019-09-26 18:19:38] |
If the parameters listed below are not in dispute, an implementation that accomplishes them in the nearterm would serve the purpose of this thread, imho. Thanks A DeMark 9-Count Setup consists of the following: _A series of nine consecutive bars that close higher or lower than the close 4 bars earlier. _9 consecutive closes “higher” than the close 4 bars prior is a “sell setup” and 9 consecutive closes “lower” than the close 4 bars prior is a “buy setup.” _Numbers 1 through 9 are placed above each qualifying bar's highs, or below each qualifying bar's lows. Perfected setups _A “sell setup” is “perfected” when the the high of bars 6 and 7 in the count are exceeded by the high of bars 8 or 9, the reverse of which is a “buy setup” "perfected". |
[2019-10-03 07:03:36] |
What's the status of the DeMark 9-Count Setup work? thx |
[2019-10-08 15:15:46] |
It is still in progress. I have been away and I am just today getting back to work. I will keep you posted.
[2019-10-15 04:05:07] |
Might it be possible to roll out an implimentation of the parameters below exclusively, if they are not in dispute? Interested traders could get experience with The DeMark 9-Count Setup. Further development would be for others to request. Thanks --- A DeMark 9-Count Setup consists of the following: _A series of nine consecutive bars that close higher or lower than the close 4 bars earlier. _9 consecutive closes “higher” than the close 4 bars prior is a “sell setup” and 9 consecutive closes “lower” than the close 4 bars prior is a “buy setup.” _Numbers 1 through 9 are placed above each qualifying bar's highs, or below each qualifying bar's lows. --- "Perfected Setup" Parameters Below are Not required on my behalf. Further development is for others to request. _A “sell setup” is “perfected” when the the high of bars 6 and 7 in the count are exceeded by the high of bars 8 or 9, the reverse of which is a “buy setup” "perfected". Date Time Of Last Edit: 2019-10-15 04:05:41
[2019-10-23 02:00:51] |
The DeMark 9-Count Setup, what's cookin'?
[2019-10-25 09:54:17] |
- Anybody Home? ? LOL |
[2019-10-29 21:34:31] |
- SC Support Tom, Anybody? The DeMark 9-Count Setup? Date Time Of Last Edit: 2019-10-29 21:36:12
[2019-10-30 12:39:33] |
User90125 - Posts: 715 |
Try e-mailing him direct (see post #10): Hi, you can send them to Tom@sierrachart.com. Thanks!
[2019-10-31 21:29:51] |
Hello, I apologize for the delay in getting back to you. I am still working on this study - there is a great deal of background reading between DeMark's two books and Perl's book. Also, I want to make sure that I correctly synthesize DeMark's updates (from the video) into the study. I will notify you in this thread when the study is finished. I thank you for your continued patience.
[2019-11-08 04:15:05] |
Tom, how 'bout doing just this part? --- A DeMark 9-Count Setup consists of the following: _A series of nine consecutive bars that close higher or lower than the close 4 bars earlier. _9 consecutive closes “higher” than the close 4 bars prior is a “sell setup” and 9 consecutive closes “lower” than the close 4 bars prior is a “buy setup.” _Numbers 1 through 9 are placed above each qualifying bar's highs, or below each qualifying bar's lows. --- |
[2019-11-13 07:47:10] |
TD 9-Count https://youtu.be/R8XD-seZ_sE?t=2331 |
[2019-11-13 20:29:56] |
I will get back to on this by the end of the week.
[2019-11-19 16:50:27] |
I have started programming the TD Setup, but I do not intend to have the study released until I am done with the full TD Sequential Study. What I will do is code up TD Setup as an Advanced Custom Study and submit the result here for feedback before I move on to TD Countdown.
Date Time Of Last Edit: 2019-11-19 16:57:58
[2019-12-14 00:01:53] |
Happy Holidays! Santa Please leave a TD 9-Count tool under the tree. Thanks and best to all! https://youtu.be/R8XD-seZ_sE?t=2410 Date Time Of Last Edit: 2019-12-14 00:09:20
