Date/Time: Sun, 05 May 2024 15:32:52 +0000
Cannot connect to Mt Gox Trading, Cannot download data
View Count: 1863
[2013-12-12 05:53:26] |
zodiacpc - Posts: 2 |
I'm trying to connect to MtGox Trading, I'm unable to connect and get data downloaded. Here is a copy of my log: Software version: 1056 | 2013-12-12 01:15:07 Usage end date: 2013-12-14 | 2013-12-12 01:15:07 Enabled for: Sierra Chart Historical Data Service. | 2013-12-12 01:15:07 Active service: Bitcoin Data (MtGox) | 2013-12-12 01:15:07 Time Zone: +00:00:00 (UTC+00) | 2013-12-12 01:15:07 2013-12-11 13:15:07 Local computer clock time | 2013-12-12 01:15:07 2013-12-12 01:15:07 GMT time | 2013-12-12 01:15:07 2013-12-12 01:15:07 Time zone adjusted time | 2013-12-12 01:15:07 Time difference to server time: 1 seconds. | 2013-12-12 01:15:07 Program path: C:\SierraChart\ | 2013-12-12 01:15:07 Data Files path: C:\SierraChart\Data\ | 2013-12-12 01:15:07 OS Version Number: 6.1 | 2013-12-12 01:15:07 Checking for new symbol settings for scmtg | 2013-12-12 01:15:07 ! NOTICE: 2 days of full use Remaining. If you would like to continue full use the software and services, | 2013-12-12 01:15:07 please purchase more usage time by selecting Help >> Purchase on the menu. | 2013-12-12 01:15:07 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:15:12 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:15:12 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:15:33 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:15:33 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:15:33 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:15:33 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:15:33 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:15:38 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:15:38 File >> Disconnect selected. | 2013-12-12 01:15:54 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:15:54 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:15:55 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:15:55 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:16:16 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:16:16 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:16:16 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:16:16 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:16:16 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:16:21 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:16:21 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:16:42 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:16:42 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:16:42 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:16:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:16:42 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:16:47 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:16:47 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:17:08 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:17:08 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:17:08 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:17:08 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:17:08 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:17:13 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:17:13 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:17:34 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:17:34 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:17:34 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:17:34 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:17:34 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:17:39 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:17:39 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:18:00 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:18:00 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:18:00 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:18:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:18:00 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:18:05 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:18:05 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:18:26 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:18:26 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:18:26 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:18:26 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:18:26 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:18:31 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:18:31 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:18:53 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:18:53 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:18:53 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:18:53 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:18:53 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:18:58 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:18:58 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:19:19 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:19:19 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:19:19 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:19:19 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:19:19 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:19:24 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:19:24 Current selected Data/Trading service: MtGox Trading | 2013-12-12 01:19:28 Checking for new symbol settings for scmtgt | 2013-12-12 01:19:28 DTC Service: Disconnected from the server. | 2013-12-12 01:19:28 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 01:19:28 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:19:28 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:19:28 Requesting symbol settings for scmtgt. Overwrite = on. | 2013-12-12 01:19:29 Request for symbol settings completed. | 2013-12-12 01:19:29 Processed received symbol settings | 2013-12-12 01:19:29 Get Wallet History not done because request is already outstanding | 2013-12-12 01:19:34 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:19:49 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:19:49 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:19:49 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:19:51 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:19:51 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 01:19:56 HD Request # 2 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:19:56 HD Request # 2 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:19:56 HD Request # 2 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:19:56 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:19:56 Requesting market depth updates for: BTCUSD if supported. | 2013-12-12 01:20:03 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:20:12 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:20:12 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:20:12 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:20:14 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:20:14 HD Request # 2 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:20:16 HD Request # 2 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:20:16 HD Request # 3 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:20:16 HD Request # 3 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:20:16 HD Request # 3 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:20:16 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:20:16 Unsubscribed from market depth data for BTCUSD | 2013-12-12 01:20:18 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:20:36 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:20:36 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:20:36 HD Request # 3 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:20:36 HD Request # 3 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:20:36 HD Request # 4 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:20:36 HD Request # 4 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:20:36 HD Request # 4 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:20:36 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:20:36 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:20:38 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:20:38 HD Request # 4 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:20:56 HD Request # 4 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:20:56 HD Request # 4 - Intraday download COMPLETE for BTCUSD | 2013-12-12 01:20:56 Real-time Intraday chart data file updates started for BTCUSD | 2013-12-12 01:20:56 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:20:59 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:20:59 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:20:59 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:21:01 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:21:01 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:21:22 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:21:22 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:21:22 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:21:24 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:21:24 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:21:45 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:21:45 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:21:45 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:21:47 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:21:47 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:22:08 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:22:08 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:22:08 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:22:10 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:10 File >> Disconnect selected. | 2013-12-12 01:22:17 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:22:17 MtGox Trading: Disconnected from trade server. | 2013-12-12 01:22:17 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 01:22:18 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:22:18 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:18 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 01:22:19 HD Request # 5 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:22:19 HD Request # 5 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:22:19 HD Request # 5 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:22:19 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:19 Trade orders request failed. | 2013-12-12 01:22:24 Server data line: {"result":"error","error":"Identification required to access private API","token":"login_error_duplicate_tonce"}" | 2013-12-12 01:22:24 HD Request # 5 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:22:39 HD Request # 5 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:22:39 HD Request # 6 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:22:39 HD Request # 6 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:22:39 HD Request # 6 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:22:39 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:39 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:22:39 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:22:39 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:22:39 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:22:41 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:41 HD Request # 6 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:22:59 HD Request # 6 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:22:59 HD Request # 7 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 01:22:59 HD Request # 7 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 01:22:59 HD Request # 7 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 01:22:59 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:22:59 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:23:02 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:23:02 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:23:02 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:23:04 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:23:04 HD Request # 7 - Error downloading historical Intraday data for BTCUSD. The network socket has been closed. Retrying download. | 2013-12-12 01:23:19 HD Request # 7 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 01:23:19 HD Request # 7 - Intraday download COMPLETE for BTCUSD | 2013-12-12 01:23:19 Real-time Intraday chart data file updates started for BTCUSD | 2013-12-12 01:23:19 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:23:25 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:23:25 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:23:25 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:23:27 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:23:27 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:23:48 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:23:48 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:23:48 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:23:50 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:23:50 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:24:11 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:24:11 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:24:11 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:24:13 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:24:13 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:24:34 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:24:34 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:24:34 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:24:36 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:24:36 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:24:58 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:24:58 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:24:58 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:25:00 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:25:00 Current selected Data/Trading service: MtGox Trading | 2013-12-12 01:25:05 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:25:21 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:25:21 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:25:21 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:25:23 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:25:23 File >> Disconnect selected. | 2013-12-12 01:25:42 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:25:42 MtGox Trading: Disconnected from trade server. | 2013-12-12 01:25:42 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 01:26:15 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:26:15 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:26:15 Position Info request failed | 2013-12-12 01:26:20 Server data line: {"result":"error","error":"Identification required to access private API","token":"login_error_invalid_rest_key"}" | 2013-12-12 01:26:20 Trade orders request failed. | 2013-12-12 01:26:20 Server data line: {"result":"error","error":"Identification required to access private API","token":"login_error_invalid_rest_key"}" | 2013-12-12 01:26:20 Trade orders request failed. | 2013-12-12 01:26:35 Server data line: {"result":"error","error":"Identification required to access private API","token":"login_error_invalid_rest_key"}" | 2013-12-12 01:26:35 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:26:36 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:26:36 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 01:26:36 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:26:38 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:26:38 Trade orders request failed. | 2013-12-12 01:26:50 Server data line: {"result":"error","error":"Identification required to access private API","token":"login_error_invalid_rest_key"}" | 2013-12-12 01:26:50 Current selected Data/Trading service: Bitcoin Data (MtGox) | 2013-12-12 01:26:51 Checking for new symbol settings for scmtg | 2013-12-12 01:26:51 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:26:51 MtGox Trading: Disconnected from trade server. | 2013-12-12 01:26:51 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:26:51 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:26:51 Requesting symbol settings for scmtg. Overwrite = on. | 2013-12-12 01:26:51 Request for symbol settings completed. | 2013-12-12 01:26:51 Processed received symbol settings | 2013-12-12 01:26:51 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:27:12 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:27:12 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:27:12 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:27:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:27:12 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:27:17 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:27:17 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:27:38 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:27:38 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:27:38 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:27:38 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:27:38 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:27:43 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:27:43 Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2013-12-12 01:28:04 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-12-12 01:28:04 To prevent further connection attempts, select File >> Disconnect. | 2013-12-12 01:28:04 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:28:04 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 01:28:04 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 01:28:09 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 01:28:09 File >> Disconnect selected. | 2013-12-12 01:28:24 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 01:28:24 Notice: Your computer's clock is off by 532 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2013-12-12 03:15:16 Current selected Data/Trading service: MtGox Trading | 2013-12-12 05:35:42 Checking for new symbol settings for scmtgt | 2013-12-12 05:35:42 Requesting symbol settings for scmtgt. Overwrite = on. | 2013-12-12 05:35:42 Request for symbol settings completed. | 2013-12-12 05:35:43 Processed received symbol settings | 2013-12-12 05:35:43 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:35:44 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:35:44 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:35:55 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:35:55 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:35:55 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:35:57 HTTP request #1 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:36:03 MtGox Trading: Get Position Info failed due to HTTP error. Will retry. | 2013-12-12 05:36:03 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:36:04 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:36:08 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:36:08 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:36:08 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:36:10 HTTP request #2 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:36:16 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:36:16 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:36:21 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:36:21 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:36:21 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:36:23 HTTP request #3 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:36:29 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:36:29 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:36:34 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:36:34 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:36:34 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:36:34 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:36:36 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:36:38 HD Request # 8 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:36:38 HD Request # 8 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:36:38 HD Request # 8 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:36:38 HTTP request #4 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:36:42 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:36:42 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:36:47 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:36:47 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:36:47 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:36:49 HTTP request #5 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:36:56 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:36:56 HD Request # 8 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:36:58 HD Request # 8 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:36:58 HD Request # 9 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:36:58 HD Request # 9 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:36:58 HD Request # 9 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:36:58 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:37:04 HTTP request #6 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:37:09 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:37:09 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:37:10 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:37:10 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:37:10 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:37:13 HD Request # 9 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:37:18 HD Request # 9 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:37:18 HD Request # 10 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:37:18 HD Request # 10 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:37:18 HD Request # 10 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:37:18 HTTP request #7 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:37:23 MtGox Trading: Get Position Info failed due to HTTP error. Will retry. | 2013-12-12 05:37:23 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:37:31 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:37:31 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:37:31 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:37:33 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:37:34 HTTP request #8 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:37:36 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:37:36 HD Request # 10 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:37:38 HD Request # 10 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:37:38 HD Request # 10 - Intraday download COMPLETE for BTCUSD | 2013-12-12 05:37:38 Real-time Intraday chart data file updates started for BTCUSD | 2013-12-12 05:37:38 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:37:42 The network socket for historical data has been closed. | 2013-12-12 05:37:42 HTTP request #9 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:37:49 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:37:49 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:37:52 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:37:52 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:37:52 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:37:54 HTTP request #10 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:38:03 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:38:03 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:38:05 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:38:05 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:38:05 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:38:07 HTTP request #11 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:38:16 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:38:16 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:38:18 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:38:18 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:38:18 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:38:19 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:38:20 HTTP request #12 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:38:29 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:38:29 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:38:31 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:38:31 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:38:31 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:38:33 HTTP request #13 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:38:43 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:38:43 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:38:45 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:38:45 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:38:45 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:38:47 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:38:49 HTTP request #14 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:38:56 MtGox Trading: Get Position Info failed due to HTTP error. Will retry. | 2013-12-12 05:38:56 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:38:58 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:38:58 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:38:58 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:39:00 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:39:04 HTTP request #15 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:39:09 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:39:09 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:39:11 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:39:11 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:39:11 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:39:13 HTTP request #16 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:39:22 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:39:22 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:39:24 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:39:24 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:39:24 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:39:26 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:39:34 HTTP request #17 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:39:35 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:39:35 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:39:38 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:39:38 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:39:38 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:39:40 HTTP request #18 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:39:48 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:39:48 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:39:51 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:39:51 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:39:51 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:39:53 HTTP request #20 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:40:03 MtGox Trading: Get Wallet History failed due to HTTP error. | 2013-12-12 05:40:03 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:40:04 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:40:04 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:40:04 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:40:04 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:40:06 HTTP request #19 returned the following error: Windows error code 12007: The server name or address could not be resolved | 2013-12-12 05:40:17 MtGox Trading: Get Order Info failed due to HTTP error. | 2013-12-12 05:40:17 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:40:17 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:40:17 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:40:17 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:40:19 Current selected Data/Trading service: MtGox Trading | 2013-12-12 05:40:27 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:40:27 MtGox Trading: Disconnected from trade server. | 2013-12-12 05:40:27 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 05:40:27 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:40:30 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:40:32 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:40:32 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:40:32 HD Request # 11 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:40:32 HD Request # 11 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:40:32 HD Request # 11 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:40:32 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:40:37 Get Wallet History not done because request is already outstanding | 2013-12-12 05:40:37 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:40:43 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:40:43 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:40:43 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:40:45 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:40:52 HD Request # 11 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:40:52 HD Request # 11 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:40:52 HD Request # 12 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:40:52 HD Request # 12 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:40:52 HD Request # 12 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:40:52 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:41:05 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:41:05 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:41:05 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:41:07 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:41:07 HD Request # 12 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:41:12 HD Request # 12 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:41:12 HD Request # 13 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:41:12 HD Request # 13 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:41:12 HD Request # 13 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:41:12 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:41:22 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:41:27 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:41:27 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:41:27 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:41:29 The data feed was lost. There was no activity for at least 60.0 seconds. | 2013-12-12 05:41:32 Connection to the external service has been lost. | 2013-12-12 05:41:32 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:41:32 MtGox Trading: Disconnected from trade server. | 2013-12-12 05:41:32 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 05:41:32 HD Request # 13 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:41:32 HD Request # 13 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:41:32 HD Request # 13 - Intraday download COMPLETE for BTCUSD | 2013-12-12 05:41:32 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:41:37 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:41:37 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:41:37 HD Request # 14 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:41:37 HD Request # 14 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:41:37 HD Request # 14 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:41:37 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:41:42 Get Wallet History not done because request is already outstanding | 2013-12-12 05:41:42 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:41:50 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:41:50 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:41:50 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:41:52 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:41:57 HD Request # 14 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:41:57 HD Request # 14 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:41:57 HD Request # 15 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:41:57 HD Request # 15 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:41:57 HD Request # 15 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:41:57 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:42:12 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:42:12 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:42:12 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:42:12 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:42:14 HD Request # 15 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:42:17 HD Request # 15 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:42:17 HD Request # 16 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:42:17 HD Request # 16 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:42:17 HD Request # 16 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:42:17 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:42:27 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:42:35 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:42:35 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:42:35 HD Request # 16 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:42:37 HD Request # 16 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:42:37 HD Request # 16 - Intraday download COMPLETE for BTCUSD | 2013-12-12 05:42:37 Real-time Intraday chart data file updates started for BTCUSD | 2013-12-12 05:42:37 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:42:37 The data feed was lost. There was no activity for at least 60.0 seconds. | 2013-12-12 05:42:37 Connection to the external service has been lost. | 2013-12-12 05:42:37 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:42:37 MtGox Trading: Disconnected from trade server. | 2013-12-12 05:42:37 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 05:42:37 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:42:42 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:42:42 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:42:42 HD Request # 17 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:42:42 HD Request # 17 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:42:42 HD Request # 17 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:42:42 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:42:47 Get Wallet History not done because request is already outstanding | 2013-12-12 05:42:47 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:42:57 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:42:57 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:42:57 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:42:59 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:43:02 HD Request # 17 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:43:03 HD Request # 17 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:43:03 HD Request # 18 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:43:03 HD Request # 18 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:43:03 HD Request # 18 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:43:03 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:43:17 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:43:19 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:43:19 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:43:19 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:43:21 HD Request # 18 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:43:23 HD Request # 18 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:43:23 HD Request # 19 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:43:23 HD Request # 19 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:43:23 HD Request # 19 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:43:23 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:43:32 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:43:41 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:43:41 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:43:41 The data feed was lost. There was no activity for at least 60.0 seconds. | 2013-12-12 05:43:42 Connection to the external service has been lost. | 2013-12-12 05:43:42 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:43:42 MtGox Trading: Disconnected from trade server. | 2013-12-12 05:43:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 05:43:42 HD Request # 19 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:43:43 HD Request # 19 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:43:43 HD Request # 19 - Intraday download COMPLETE for BTCUSD | 2013-12-12 05:43:43 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:43:47 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:43:47 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:43:47 HD Request # 20 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:43:47 HD Request # 20 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:43:47 HD Request # 20 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:43:47 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:43:52 Get Wallet History not done because request is already outstanding | 2013-12-12 05:43:52 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:44:03 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:44:03 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:44:03 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:44:06 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:44:07 HD Request # 20 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:44:07 HD Request # 20 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:44:07 HD Request # 21 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:44:07 HD Request # 21 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:44:07 HD Request # 21 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:44:07 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:44:22 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:44:26 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:44:26 Bitcoin Data (MtGox): Data feed disconnected. Will reconnect. | 2013-12-12 05:44:26 HD Request # 21 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:44:27 HD Request # 21 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:44:27 HD Request # 22 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:44:27 HD Request # 22 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:44:27 HD Request # 22 - Using server: btc.sierracharts.com port 10149 | 2013-12-12 05:44:27 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:44:28 MtGox Trading: Get Orders Info not done because request is already outstanding. | 2013-12-12 05:44:37 The data feed was lost. There was no activity for at least 60.0 seconds. | 2013-12-12 05:44:47 Connection to the external service has been lost. | 2013-12-12 05:44:47 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 05:44:47 MtGox Trading: Disconnected from trade server. | 2013-12-12 05:44:47 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 05:44:47 HD Request # 22 - Error downloading historical Intraday data for BTCUSD. Timeout error connecting to server. | 2013-12-12 05:44:47 HD Request # 22 - Received 0 records and wrote 0 records for BTCUSD | 2013-12-12 05:44:47 HD Request # 22 - Intraday download COMPLETE for BTCUSD | 2013-12-12 05:44:47 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:44:48 The network socket for historical data has been closed. | 2013-12-12 05:44:48 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 05:44:52 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 05:44:52 MtGox Trading - Starting real-time market data updates for: BTCUSD | 2013-12-12 05:44:52 HD Request # 23 - Downloading Intraday chart data for BTCUSD to the file BTCUSD.scid. Service: mtg | 2013-12-12 05:44:52 HD Request # 23 - Last Date-Time in file: 2013-12-04 16:22:26.0 | 2013-12-12 05:44:52 HD Request # 23 - Using server |
[2013-12-12 10:42:45] |
This log is showing that all of the connections are failing and not connecting to the servers due to connectivity and network address resolution problems from your side. Refer to help topic 1.2 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails1.html There are three different connections being tried to be made, and each and every one of them is failing from your system. If you are running firewall software, completely disable it. The Windows firewall is usually not a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-12 11:05:59
[2013-12-12 10:44:11] |
For an error like this, usually restarting your computer will solve it: Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-12-12 05:43:19 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-12 22:05:30] |
zodiacpc - Posts: 2 |
Thanks for the response. I'm still getting a similar error, the data isn't downloading and it is not picking up my Mt Gox wallet information. Here's a copy of my log. Software version: 1056 | 2013-12-12 21:58:02 Usage end date: 2013-12-14 | 2013-12-12 21:58:02 Enabled for: Sierra Chart Historical Data Service. | 2013-12-12 21:58:02 Active service: MtGox Trading | 2013-12-12 21:58:02 Time Zone: +00:00:00 (UTC+00) | 2013-12-12 21:58:02 2013-12-12 09:58:02 Local computer clock time | 2013-12-12 21:58:02 2013-12-12 21:58:02 GMT time | 2013-12-12 21:58:02 2013-12-12 21:58:02 Time zone adjusted time | 2013-12-12 21:58:02 Time difference to server time: 2 seconds. | 2013-12-12 21:58:02 Program path: C:\SierraChart\ | 2013-12-12 21:58:02 Data Files path: C:\SierraChart\Data\ | 2013-12-12 21:58:02 OS Version Number: 6.1 | 2013-12-12 21:58:02 Checking for new symbol settings for scmtgt | 2013-12-12 21:58:02 ! NOTICE: 2 days of full use Remaining. If you would like to continue full use the software and services, | 2013-12-12 21:58:03 please purchase more usage time by selecting Help >> Purchase on the menu. | 2013-12-12 21:58:03 MtGox Trading - Connected to trade server: https://data.mtgox.com/api/2/ | 2013-12-12 21:58:07 Bitcoin Data (MtGox): Connecting to the server btc.sierracharts.com. Port 10050 | 2013-12-12 21:58:07 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-12 21:58:07 Get Wallet History not done because request is already outstanding | 2013-12-12 21:58:13 File >> Disconnect selected. | 2013-12-12 21:58:24 Bitcoin Data (MtGox): Disconnected from the server. | 2013-12-12 21:58:24 MtGox Trading: Disconnected from trade server. | 2013-12-12 21:58:24 |
[2013-12-13 01:12:34] |
What data is not downloading? When you open a chart through File >> Find Symbol, does the chart remain blank? Get Wallet History not done because request is already outstanding | 2013-12-12 21:58:13 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
