Date/Time: Tue, 15 Jul 2025 19:20:05 +0000
[Programming Help] - Issue using sc.GetStudyProfileInformation function
View Count: 1148
[2019-09-13 05:16:11] |
User650124 - Posts: 6 |
I'm working on an ASCIL trading system where i need to call information from a VbP study on my chart. When i attempt to program this function i am receiving the following errors when i go to build, among others: error C2065: 's_StudyProfileInformation': undeclared identifier error C2039: 'GetStudyProfileInformation': is not a member of 's_sc' Is this function not supported anymore, or have i made a mistake in the way i set up the structure and call upon the function? I've copied my code below for your reference. I've used many other functions successfully and tried many different ways of setting this one up but unfortunately haven't been able to figure this one out. Thanks for your time. s_StudyProfileInformation StudyProfileInformation; sc.GetStudyProfileInformation(6, 0, StudyProfileInformation); float POC = StudyProfileInformation.m_VolumePOCPrice; float ValueAreaLow = StudyProfileInformation.m_VolumeValueAreaLow; |
[2019-09-13 06:22:17] |
User907968 - Posts: 842 |
Did you try the following delcaration? n_ACSIL::s_StudyProfileInformation StudyProfileInformation;
s_StudyProfileInformation is not in the global scope, it is scoped in namespace n_ACSIL. |
[2019-09-13 08:24:43] |
Yes post #2 is the solution to the problem.
[2019-09-13 14:09:47] |
Thanks for the response, i had already tried that an unfortunately that didn't work. my updated code is below for review: n_ACSIL:: s_StudyProfileInformation StudyProfileInformation; sc.GetStudyProfileInformation(6, 0, StudyProfileInformation); float POC = StudyProfileInformation.m_VolumePOCPrice; float ValueAreaLow = StudyProfileInformation.m_VolumeValueAreaLow; The new error is below: C2039: 's_StudyProfileInformation': is not a member of 'n_ACSIL' |
[2019-09-14 07:45:13] |
Please disregard, i updated my sierrachart to the latest version and the problem fixed itself. Thanks
