Date/Time: Thu, 09 May 2024 14:48:54 +0000
SC Memory leak
View Count: 646
[2019-09-12 18:03:47] |
N!co - Posts: 140 |
Hi, I have 3 seperate instances of SC running each with a similar amount of charts But , one of the SC running has it's memory creaping up , to the point that it becomes unresponsive one way i have found to temporary fix and lower the memory consumption without a restart, is to go into general settings and change the "Chart Update Interval In Milliseconds" changing this will cause the memory to drop, but will start creeping up again afterwards Do you have any idea what could be the problem ? thx |
SC Memory problem.jpg / V - Attached On 2019-09-12 18:03:30 UTC - Size: 26.55 KB - 269 views SC Memory problem2.jpg / V - Attached On 2019-09-12 18:03:34 UTC - Size: 26.15 KB - 251 views |
[2019-09-12 20:56:37] |
Must be caused by a custom study. It is not Sierra Chart with a memory leak. Refer to help topic 17: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-12 21:04:49] |
N!co - Posts: 140 |
No custom studies are being used the only studies used are : MA, timelines , countdown timer, Daily OHLC |
[2019-09-12 23:25:58] |
It is not Sierra Chart with a memory leak. If there really is a memory leak, it is caused by something else on your system running within the same address space, or the memory usage is just based upon what you are doing with that particular Sierra Chart instance. Sierra Chart has no memory leaks at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
