Date/Time: Wed, 08 May 2024 17:42:41 +0000
Limiting total number of open contracts
View Count: 644
[2019-09-12 17:22:50] |
User404734 - Posts: 1 |
Is there an area that will allow the user to limit the total number of open contracts in the menus? This is geared towards the trading combines out there where you may be limited to a total of 2 open contracts at any one time. Say you fat fingered the mouse and accidentally hit the buy button twice on a 2 lot trade. Now a rules violation. Is there a default quantity that can be set to avoid this situation? Like the platform! |
[2019-09-12 23:56:47] |
Yes. Refer to: Global Symbol Settings: Use Global Trade Position Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
