Date/Time: Thu, 09 May 2024 13:24:55 +0000
Do I need to pay Extra to get the BitMEX symbols or am I doing something wrong ?
View Count: 506
[2019-09-12 13:06:04] |
User612903 - Posts: 51 |
Hello, Up to here I was displaying the crypto markets using Bitfinex, but I understand you are stoping to support this platform. So I understand from your doc that the best way to get cryptos in Sierra is BitMEX (correct ?). But when I connect to the "Cryptocurrencies Data - DTC [data]" service in Sierra, this is all I get (cf screenshot). I'm looking for a standard list (BTCUSD, LTCUSD, ETHUSD, etc ...). Is this still possible with Sierra ? Do I need to register to BitMex api and connect to the BitMEX data service ? Thank you for your help, Regards, |
Capture-crypto.PNG / V - Attached On 2019-09-12 13:05:30 UTC - Size: 65.4 KB - 213 views |
[2019-09-12 13:15:08] |
Or does this mean BitMex only supports a few cyptos ? If this is a case is there any other way to get a bigger list of crypto in Sierra, at least 30 ? |
[2019-09-12 13:53:08] |
Those are all the symbols Bitmex has. Be sure to scroll down the list. We are looking at another provider for more symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-12 14:14:13] |
Thank you for you quick reply. I understand you can't give me an exact answer but do you think this will take weeks, months ? After 2020 ? Regards |
[2019-09-12 23:38:45] |
It would definitely at the soonest be months and not be until sometime in 2020.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 23:39:35
