Date/Time: Thu, 09 May 2024 15:47:38 +0000
Sierra chart export data price deviation
View Count: 517
[2019-09-12 10:29:11] |
User740266 - Posts: 26 |
I was using number of trades (1) chart and when I was exporting the bar data, the OHLC price is at the same price. But once I tried to export the data using the export intra day data, the OHLC price for a particular trade severely deviated from each other. May I know what causes the problem and how I could fix this? Thanks.
[2019-09-13 00:03:24] |
The data should be exactly the same if you are using 1 trade per bar. Be sure you are looking at the same date and time between the two files. The most recent data is at the end of the file, and also keep in mind that the times are relative to different time zones. The Intraday Export is in UTC time, whereas the Bar Data is in the time zone of the chart.
