Date/Time: Mon, 06 May 2024 10:06:58 +0000
DOM on chart coverage
View Count: 485
[2019-09-11 19:41:24] |
User837393 - Posts: 132 |
Hello, Currently using DOM On Chart. Is there a way to define how far the DOM is going ... Right now the depth is covering for about 100 ticks. Where can I modify this for let say I'd like to cover 20 ticks up and down from last price ? Best regars. |
[2019-09-12 04:37:22] |
Refer to the following: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
