Date/Time: Mon, 29 Apr 2024 11:35:22 +0000
Price Consolidation on TradeDOM
View Count: 1044
[2019-09-11 18:34:38] |
seandunaway - Posts: 213 |
Would you please allow prices (scale increment values) to be consolidated on the TradeDOM? Without it, some securities are untradeable. I've included a screenshot of how ThinkorSwim and TT handle this. I'm happy to provide any product manuals, screenshots or additional details. Thank you for your consideration! attached Date Time Of Last Edit: 2019-09-11 18:45:29
price consolidation.png / V - Attached On 2019-09-11 18:34:08 UTC - Size: 190.43 KB - 309 views |
[2019-09-11 19:33:38] |
I've been manually multiplying my Tick Size and Currency Value Per Tick but it's a lot to keep up with many products and seems potentially dangerous live? Are there any side effects?
[2019-09-12 04:20:34] |
This already exists. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Also refer to: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-12 04:33:54] |
Yes, combining the Market Depth is helpful but I'm referring to combining the price scale. Scale Settings -> Scale Increment, does not work correctly for me on a TradingDOM. Am I missing something? |
scale increment.png / V - Attached On 2019-09-12 04:33:34 UTC - Size: 44.54 KB - 301 views |
[2019-09-12 11:31:10] |
Thank you for the change made in v1987 regarding the Scale Increment to be honored. However, do you see how this way isn't helpful for us TradeDOM users and not how implemented in other ladders? Is it possible to take advantage of the Scale Increment while keeping prices stacked in a ladder as described with ThinkorSwim and TT, etc? attached Date Time Of Last Edit: 2019-09-12 11:58:03
scale increment 1987.png / V - Attached On 2019-09-12 11:31:02 UTC - Size: 54.37 KB - 287 views scale increment TT.png / V - Attached On 2019-09-12 11:40:26 UTC - Size: 530.28 KB - 335 views scale increment X_Trader.png / V - Attached On 2019-09-12 11:57:51 UTC - Size: 172.92 KB - 300 views |
[2019-09-12 12:03:24] |
I just want to add that I'm okay with manually multiplying the chart's TickSize and CurrencyValuePerTick to accomplish this, but I'd just like to verify with you this is supported and shouldn't have any side effects. I'd hate to be thinking my P&L is one thing and then be ninja blowing an account behind the scenes, when managing many products. |
[2019-09-13 08:18:05] |
Yes it is perfectly fine to change the Tick Size and make a corresponding change to Currency Value per Tick. There is no problem with this. There is no trading safety problem with doing anything like that.
[2019-09-17 11:33:36] |
After making the required changes, you will also want to compress the price scale as needed: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-17 11:33:52
