Date/Time: Mon, 29 Apr 2024 13:26:07 +0000
No updates
View Count: 526
[2019-09-11 18:24:01] |
User431011 - Posts: 2 |
I´ve downloaded sierra 14 days trial version. Opening a chart works but then there is no updates. Trading dom looks naked, also no updates. Looks like I´m connected to data feed because of green field in left corner ....
[2019-09-12 00:51:56] |
Refer to the documentation here: Real-Time Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-12 07:15:28] |
SC Data All Services is not possible?
[2019-09-12 07:44:46] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. We expect in about two weeks, to offer delayed streaming futures data at no additional cost. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 07:45:05
