Date/Time: Tue, 14 May 2024 08:35:21 +0000
[User Discussion] - Is there an easier way to place trades from selected DOM settings.
View Count: 650
[2019-09-11 18:17:52] |
User339484 - Posts: 71 |
The one issue I have with Sierra Charts DOM is that there is no way to quickly place a custom order that isn't based off a normal buy/sell. Sure, the custom orders work where if I wanted to add a bid/ask quantity stop to an order 2 ticks above I can just attack the orders and click the DOM and it adds the stop 2 ticks above with the set quantity. But this only works as a chained order where the original buy/sell has to fill first. But what if I just wanted to play a quantity stop 2 ticks above? 1. I have to customize the settings at the bottom of the DOM 2. I have to use the drop down and scroll to the correct number 3. I have to hit buy/sell That takes quite some time. I was wondering if there was an easier way? There could be a checkmark, like how you add attached orders. You click the check mark and the initial order is customized from the bottom part like is done with the top. See a mock up here. https://imgur.com/a/jyVORnP That would make things much easier and faster. |
Attachment Deleted. |
