Date/Time: Thu, 09 May 2024 03:48:02 +0000
AMP and stock data
View Count: 794
[2019-09-11 18:16:43] |
User790363 - Posts: 1 |
Hi team, I'm going to open an account with AMP to trade futures on live account. I'm aware that you cooperate with AMP and pricing for charting package is diffrent. Would it possible though to get data for NYSE stocks as well as a separate paid service at the same time or using new instance of Sierra Charts? Data for stocks could be delayed or could be real time depending on price. Please advise. Kind regards |
[2019-09-12 04:37:55] |
Yes this is available. If you need real-time data you need to use this service: Sierra Chart Exchange Data Feed If you just want historical data, then you must have a direct account with Sierra Chart not through AMP and then you will use this service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
