Date/Time: Wed, 15 May 2024 09:50:46 +0000
Services quote
View Count: 378
[2019-09-10 23:46:10] |
Handle - Posts: 36 |
Ok so far this morning running AT 1985 through the opening 30 min in the ES with above average volume I’m seeing very little, negligible, lag from chart to TA DOM Will continue to watch and report in the existing support thread Thanks |
[2019-09-11 00:00:53] |
This is good to know but you should also be running version 1986.
