Date/Time: Mon, 29 Apr 2024 20:26:35 +0000
Windows 7 Update December 10 2013 Issue?
View Count: 1231
[2013-12-11 17:43:25] |
1. No. 2. You should have no trouble installing any version of Sierra Chart. What is the exact error message you are getting? You should never have to do this, although maybe you need to delete a file that the installer is unable to write. But we need to know what the error message is. 3. The problem most likely is going to be from the operating system caching data as Sierra Chart reads the Intraday data files. Sierra Chart does allocate additional memory per chart for file caching. We will reduce this in the next version. Currently this is 2.5 MB per chart. How many charts do you have open? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-11 17:52:09
