Date/Time: Fri, 03 May 2024 20:26:51 +0000
Resolution - small buttons
View Count: 718
[2019-09-09 16:59:48] |
User723938 - Posts: 2 |
Hi, I changed my computer and installed Sierra, but the buttons and chartbooks are very small. Can I change overall size of that in sierra? Regards Pawel |
Screenshot_1.png / V - Attached On 2019-09-09 16:58:49 UTC - Size: 124.49 KB - 210 views Attachment Deleted. |
[2019-09-09 17:20:43] |
You need to increase the font size for the text used for those elements which is too small. Refer to: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-09 17:20:49
