Date/Time: Mon, 09 Nov 2026 09:38:18 +0000
Large number format for Current Traded Volume
View Count: 1760
| [2019-09-08 16:03:12] |
| Unseen - Posts: 1 |
Is there any option for a large number format for current traded volume in DOM column? Original name: Current Traded (Bid/Ask) Volume |
| [2019-09-09 17:46:33] |
| John - SC Support - Posts: 48459 |
This has been done and will be in the next Pre-Release (v 1987). The Current Traded column will display using the Large Number Formatting, as does the Market Depth and Recent Bid columns already do.
| [2020-09-12 10:07:31] |
| ticinotrader - Posts: 431 |
Dear Support, Is there a possibility/option to enable the previous display mode? I mean displaying the full volume numbers instead of 'K' or 'M' Large Number Format? I tried to find it in SC, without success. Thank you. |
| [2020-10-28 02:35:40] |
| User471548 - Posts: 29 |
+1 How can I disable the Large Number Format for current traded volume in the DOM columns?
| [2020-11-04 17:48:37] |
We have added a new option on the Trade >>Customize Chart/Trade DOM Columns settings window called Use Size Suffix. This controls whether a column displays the data in the Large Integer with Suffix format or not. By default this option is enabled, so the numbers will display in the Large Integer with Suffix format unless turned off. The documentation for this can be found here: Global Trade Settings Windows: Use Size Suffix This change will be in the next Pre-Release v 2192. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-05 20:50:08
