Date/Time: Mon, 29 Apr 2024 12:08:42 +0000
CONNECT CQG
View Count: 547
[2019-09-07 16:51:43] |
User542881 - Posts: 1 |
Hi, I want to connect to CQG data, but the error message tells me that the user does not exist for CQG FIX Trading. Error also appears in CQG API. Can you help me make the connection? P.D. CQG sent me username and password to connect |
[2019-09-09 06:05:00] |
In our experience any username you get directly from CQG cannot be used in Sierra Chart. CQG needs to be used only through brokers. Refer to the error messages section here for help for the error message you are getting: CQG Trading Platform Service: Common Error Messages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-09 06:05:57
