Date/Time: Sun, 28 Apr 2024 14:00:08 +0000
app title bar
View Count: 1101
[2013-12-11 02:26:24] |
Todd - Posts: 62 |
I think the title bar should have the service/data provider listed first in the title if it is set in global. I have four separate instances running and keeping them straight is difficult because the chartbook name is at the front of the string and thus I can't see the service provider on the taskbar. If some people like it the existing way perhaps this could be an option to retain existing behavior. Thanks. |
[2013-12-11 02:43:51] |
We will change this to show the program name first. The program name can be customized through Global Settings >> General Settings >>General 2 Custom Title Bar Name. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
