Date/Time: Mon, 29 Apr 2024 14:20:08 +0000
The Different between Backtest-modis
View Count: 518
[2019-09-06 17:56:20] |
User483082 - Posts: 8 |
Dear Support, At the beginning I would like to say that your software is really good. I have the following basis: automatic ACSIL Study on renkocharts ... I have done backtestings and found that there are significant differences between the > Bar baktest < version and the > replay backtest < version. According to their help page, it's because the > bar-backtest < version only uses Open high low close !? -> there is the possibility somehow the environment settings (entrys etc ...) of > Bar backtest < to integrated in life-trading? Background: what was already presumed in advance, the best backtest result has resulted in > Bar backtest < ! my question because this is clearly NOT in the help page: ----> which backtest version is very close to the life trading? <------ I thank you for your answers. Satisfied customer. |
[2019-09-09 18:02:26] |
Hello any there?
[2019-09-09 20:24:25] |
We apologize for the delay. the > bar-backtest < version only uses Open high low close !? Yes this is the case.The back test which is going to be closest to live trading will be a replay tick by tick back test. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-10 00:05:16] |
Thanks for the good Answer. bye |
