Date/Time: Tue, 07 May 2024 14:42:57 +0000
Sierra Chart on macOS with wine
View Count: 8682
[2020-04-11 06:21:01] |
Version 2021 is available. Instructions to install that version are here: Software Download: Software Rollback Procedure If you have any trouble getting it following those instructions let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-11 06:39:42] |
yellowandy - Posts: 20 |
Thank you but I downloaded and upgraded using the .zip approach and am no longer able to launch Sierra to access the download manager. Do you happen to have a direct link to the zip file? Looks like online you only keep the last month or so of releases: https://www.sierrachart.com/index.php?page=doc/SCZipInstallerList.php . I am going to build a dedicated machine to Sierra next month but still need to order parts and will be a month or so. Unfortunately I can't open it at all after the upgrade (I know I should have backed it up but before hand but I was lazy, thought I could revert no problem).
[2020-04-11 07:22:40] |
Sierra_Chart Engineering - Posts: 14256 |
The .zip file is attached.
SierraChart2021.zip - Attached On 2020-04-11 07:19:06 UTC - Size: 18.88 MB - 415 views |
[2020-04-11 07:38:17] |
Thank you so much, I got everything working again which means I can trade again Monday and build out my rig next month. Much appreciated!
[2020-04-12 00:15:05] |
Mack - Posts: 83 |
@yellowandy: It's actually possible to run more recent versions of Sierra Chart but you need to manually start the 32 bit version. Just make sure that you start the right "exe file" from the terminal. (see above)
Date Time Of Last Edit: 2020-04-12 00:16:01
[2020-04-12 06:28:45] |
Mack, I get the following: wine64 SierraChart.exe wine: Bad EXE format for C:\SierraChart\SierraChart.exe. That's with MacOS Catalina and wine 4.0.2. Will try updating wine later to see if that makes a difference. |
[2020-04-12 07:54:38] |
When you want to run the 64-bit version of Sierra Chart you need to use SierraChart_64.exe
[2020-04-13 11:18:59] |
Mack - Posts: 83 |
Hi Yellowandy, Apple has dropped 32bit support with the release of OSX Catalina (10.15.x) BUT. There are still options! I haven't tested this myself though: 1. Install wine 5 on Catalina, but stick to the 64 bit 2021 build of SC. You need 64 bit because your OS is 64 bit. 2. Install Crossover 19 and run the 32 bit 2083 of Sierra. Date Time Of Last Edit: 2020-04-13 16:23:32
[2020-10-25 11:32:29] |
maskenJL - Posts: 20 |
Can Confirm Mojave with Wine 5 + Build 2163 works if u use the 32Bit exe. Also if ur Fonts are kinda off .... GoTo Global Graphic settings in Sierra -> Fonts and set every single point back to Defaults. Mac OS kinda screws with the fonts and trys to replace it with an apple font. Date Time Of Last Edit: 2020-10-25 11:44:25
[2020-10-26 12:08:28] |
mpro - Posts: 44 |
I am using Sierra Chart with Parallels 16 in Big Sur and Catalina. It works very fast no perfomance issues at all. I have compressed Intraday Data files (older than one week). I would recommend Coherence Mode (windowed). Specs: Intel i9-7900X (10 core) + 32GB RAM Date Time Of Last Edit: 2020-10-26 12:19:43
[2020-10-26 15:45:40] |
Tony - Posts: 460 |
@mpro Thanks for the info, wonder if your data feed app Windows or Mac? I am not sure if Sierra Chart in Parallels would be able to communicate with a Mac app via API?
[2020-10-26 15:49:13] |
mpro - Posts: 44 |
All in windows VM. I am using a hackintosh. I noticed that my VM perfomance increased when running with VT-D enabled. I don't know how it is with normal mac.
Date Time Of Last Edit: 2020-10-26 15:56:02
[2021-01-02 07:19:16] |
User208416 - Posts: 33 |
i believe sierra chart 2166 is the last version supporting 32 bit. so 2166 should work under 32 bit
[2021-01-02 07:22:11] |
Why do you need to use the 32-bit version of Sierra Chart at this time?
[2021-01-02 08:23:55] |
User696749 - Posts: 9 |
Can confirm 2163 is working in 64bit with Wine.
[2021-01-02 08:45:40] |
How about the latest 64-bit version of Sierra Chart on WINE? Are you running into a problem? Really not sure why that would be.
[2021-01-02 09:10:44] |
Latest version wont nur at all neither 32 or 64bit on Mojave and Wine 5. Can post the error log later.
[2021-01-02 16:31:55] |
what version of wine do you use ? @User696749
[2021-01-02 19:41:51] |
Version 2164 and above do not un on mac using either Wine or Crossover. I have never been able to get the 64 bit version of any sierra versions to run on Mac with Wine. as 32 bit version of mac was disabled at sierra version 2177, iam unable to upversion my charts to the most recent version. Stuck at 2164 version on mac.
[2021-01-02 21:01:22] |
@Sierra Chart Engineer How about the latest 64-bit version of Sierra Chart on WINE? Are you running into a problem? Really not sure why that would be.
I added the Log file, this happens since 2164 version on Mac. Wine has not changed and aim still on Mojave every version before 2164 works perfectly. |
notworkingabove2163.txt - Attached On 2021-01-02 20:59:38 UTC - Size: 24.44 KB - 277 views |
[2021-01-02 23:06:03] |
i concur with maskenJL. 2164 is the last working version using WINE on MAC. i use high sierra though
[2021-01-04 02:36:25] |
This is the relevant information: Unhandled exception: page fault on read access to 0x00000020 in 64-bit code (0x0000000140f4a0e2).
Register dump: rip:0000000140f4a0e2 rsp:0000000001bffd60 rbp:0000000001bfffd0 eflags:00010246 ( R- -- I Z- -P- ) rax:0000000000000000 rbx:0000000000000001 rcx:0000000000000000 rdx:00000001413aab18 rsi:0000000001bffde0 rdi:0000000000000000 r8:00000001413d67a0 r9:0000000001bffd20 r10:00006b637d11827a r11:0000000000000000 r12:0000000000000000 r13:0000000000000000 r14:00000000012f8500 r15:0000000000000000 Stack dump: 0x0000000001bffd60: 0000000000000000 0000000000000000 0x0000000001bffd70: 0000000000000005 0000000000000005 0x0000000001bffd80: 00000000012f8500 0000000140f31bf2 0x0000000001bffd90: 0000000000000000 0000000001bffde0 0x0000000001bffda0: 0000000000000000 0000000000000000 0x0000000001bffdb0: 0000000140f31bc4 000000007bc91c13 0x0000000001bffdc0: 0000000000000000 0000000000000000 0x0000000001bffdd0: 0000000000000000 0000000000000000 0x0000000001bffde0: ffffffffffffffff 000000007bcb5370 0x0000000001bffdf0: 000000007bc40350 0000000000000000 0x0000000001bffe00: 0000000001bffde0 0000000140f31bc4 0x0000000001bffe10: 0000000001bffdc0 0000000001bfffd0 Backtrace: =>0 0x0000000140f4a0e2 EntryPoint+0x100051876() in sierrachart_64 (0x0000000001bfffd0) 1 0x0000000140f31bf2 EntryPoint+0x100039385() in sierrachart_64 (0x0000000001bfffd0) 2 0x000000007bc91c13 call_thread_func+0xd2() in ntdll (0x0000000001bfffd0) 0x0000000140f4a0e2 EntryPoint+0x100051876 in sierrachart_64: movq 0x0000000000000020(%rax),%rcx We want you to enable Message Log logging in Sierra Chart: Message Log: Automatically Saving Message Log to File And then run Sierra Chart again and then provide us the log file at the time you run into the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-04 06:48:18] |
Sorry but this is not possible as it crashes before login. It has not even created a sierra cfg. I tried coping a different sierra cfg with log enabled but it wont get that far
[2021-01-04 07:08:34] |
ok i have figured out with some trouble shooting how to install version 2215 using crossover on mac. Iam using the following tools: macbook with Bigsur OS Cross over version 20.0 When you create a bottle you need to create the bottle with Windows 10 ( 64 bit version). This does not work with Windows 7 (64 bit ) bottle. 64 bit is to be used as new Sierra chart versions > 2177 support only 64 bit. once the bottle is created you just have to search for sierra chart and install the latest version ( by default). it downloads the latest version by default. let me know if you run into any issues. Its working with big sur and i believe it will work with other older versions like catalina, high sierra and Mojave. |
[2021-01-04 07:50:13] |
ganz - Posts: 1048 |
https://www.codeweavers.com/crossover#requirements
[2021-01-04 08:28:02] |
Sorry but this is not possible as it crashes before login Ok. This would probably indicate, the problem is not something that is within our control.Is the information given in post #48 helpful to you to get the latest 64-bit version running on your system? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
