Date/Time: Sat, 04 May 2024 08:48:06 +0000
SC v.929 with Interactive Brokers and CTS T4 data
View Count: 1333
[2013-12-10 18:16:11] |
jagoankita - Posts: 24 |
I use spreadsheet for autotrading ES futures on SC v.929 with Interactive Brokers. Now at the same computer I have CTS T4 (Trial/Sim) on SC v.929 with Advantage Futures Broker. Can I use CTS market data to trade with Interactive Broker using my old Sierra Chart v.929 ? CTS futures displays ES 180450 instead of 1804.50. How to change the setup, I prefer data with decimal(1804.50). Thank you. |
[2013-12-10 18:52:23] |
We cannot comment on older versions of Sierra Chart. We only support newer versions since this is what we currently work with. You should be able to use CTS T4 data and have the multiplier properly adjusted through the multiplier settings in Chart >> Chart Settings. However, the most reliable way to do this is to use the Sierra Chart Real-time and Historical Futures data feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 18:52:41
