Date/Time: Sun, 19 May 2024 15:52:33 +0000
[User Discussion] - Zigzag text not visible when scale range is automatic
View Count: 570
[2019-09-04 21:01:30] |
samual sprat - Posts: 343 |
Hi, When adding zigzag to price with scale setting set to Automatic, when I add text to the ZZ swings (for example Ticks) with 'Text Label Offset' at 1 or more the text is not visible on the chart when the chart scale is Automatic. Is it possible to fix this so that if Automatic scale is selected in ZZ then the text will always be visible? Thanks |
[2019-09-05 00:48:32] |
You just need to compress the scale some to see the text: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-06 10:06:26] |
Thanks. I do this at the moment but it seems like a workaround to me. I have to adjust the scales all the time to see market historical depth study above and below price. So I use 'Interactive Scale Range' and 'Interactive Scale Move' all the time. It would be far more efficient if we only needed to set the scales to 'Interactive Scale Move' and then double click the scales to reset them and the ZZ text was visible straight away instead of having to do 3-4 things to get all ZZ text visible again once I'm done with moving scale
