Date/Time: Sat, 04 May 2024 23:59:43 +0000
[User Discussion] - Multiple Instances Consolidating
View Count: 918
[2019-09-04 20:14:02] |
User379468 - Posts: 508 |
Is there a way SC can develop some simple automated ways of doing some of these things? Syncing settings, chartbooks, changes to chartbooks between multiple instances? It is very cumbersome to maintain all these individually across instances. Also is there a way SC can manage the whole multiple instances setup all in the background to utilize additional CPU cores, so it's invisible to the user? |
[2019-09-04 20:39:29] |
samual sprat - Posts: 343 |
I'd like to add study syncing to this list.... great idea, really need something like this |
[2019-09-09 02:54:10] |
How can we at least sync settings and chartbooks and configurations easily between multiple instances so we don't have to tediously make every single change manually duplicated across every single instance?
[2019-09-09 08:43:02] |
mpro - Posts: 44 |
For files you can use FreeFileSync. https://freefilesync.org/ |
[2019-09-09 19:40:53] |
Which files can be used to only sync simple things like control bars, or symbol settings, or color and font settings, without overriding other important configurations?
