Date/Time: Mon, 06 May 2024 14:32:47 +0000
US 2 Year Note Tick Size Wrong, CQG/SC Feed
View Count: 793
[2019-09-04 18:47:26] |
User379468 - Posts: 508 |
It's 1/8 of a 32nd, not 1/4, per CME page.
[2019-09-05 01:42:02] |
The settings are correct. You should see this: 0.125/32 Follow the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-05 01:48:58] |
I updated from server and it was still showing 0.25/32 in the global symbol settings. I manually edited them to 0.125/32.
