Date/Time: Thu, 02 May 2024 21:35:27 +0000
2 Indicators in same Region Scale issue
View Count: 675
[2019-09-04 16:57:39] |
User231754 - Posts: 11 |
Having a Scale issue with 2 Indicators i am currently using in an Older Version 1595 of Sierra Chart. I know it is very old version. Currently in this older version 1595 they are working Perfectly as i want which Allows me to Adjust/Contract- a Zero Line Based Histogram Indicator by Left-click and hold on the Values Scale of numbers on the right side of the Indicators Region, and Adjust the Scale of the Histogram Indicator, but the other Indicator will stay Locked. I am not able to Duplicate this Adjustment with these 2 Indicators in the Same Region while using Version 1978. It is Mandatory that we have to Upgrade soon so i need to find a Solution. Please help and Thanks in Advance. |
[2019-09-05 01:45:47] |
There are a couple of options available. - One option is to turn on the Left-Side scale and then set the 2nd indicator to an Independent scale. Then when adjusting the scales on the right, the second indicator will not move, and when adjusting the scales on the left, the first indicator will not move. Refer to the documentation for this here: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) - Another option is to set the second indicator to a Scale setting of Automatic Zero-Based or Automatic Zero-Centered. These options will lock the indicator in place and not let it move. Refer to the documentation for these settings starting here: Chart Scale and Scale Adjusting: Automatic Zero-Based (Scale Range) In either case, the documentation for setting the scale of a study can be found here: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-05 09:38:45] |
I will work with this information to see if i can get it to work. Thank you for these links, and your Quick Response. |
