Date/Time: Sun, 19 May 2024 06:58:41 +0000
command line tools
View Count: 805
[2019-09-04 15:41:55] |
jseppa - Posts: 18 |
Hi, I'm currently using cl.exe to build. In order to release the DLL whilst developing, I'm using the options in the "Build Advanced Custom Studies DLL" window (Release/Allow) Is there a way developers can do these tasks via command line to speed up the process? I'd like to add it to my cl.exe compile script. Cheers, Jason |
[2019-09-06 13:22:12] |
Any chance of doing this via command line? I'm currently finding the quickest way is to exit the program and start it again. Not a great option
[2019-09-06 19:01:53] |
No there is not, but you can do this through the UDP interface: UDP Interface And there is also a keyboard shortcut which can be configured for the relevant commands: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) You will find them at the bottom of the list of "Commands". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-07 00:01:07] |
yeh the UDP interface works perfectly. C:\SierraChart\ACS_Source>sc-udp.exe --release --dll C:\SierraChart\Data\FF_Studies_64.dll sendMessage [RELEASE_DLL--C:\SierraChart\Data\FF_Studies_64.dll] C:\SierraChart\ACS_Source>sc-udp.exe --load --dll C:\SierraChart\Data\FF_Studies_64.dll sendMessage [ALLOW_LOAD_DLL--C:\SierraChart\Data\FF_Studies_64.dll] I should look at the TOC in the docs for next time :-) |
