Date/Time: Thu, 02 May 2024 00:25:31 +0000
Volume bars on DOM too T H I C C. Order details too L O N G
View Count: 975
[2019-09-04 15:25:34] |
User339484 - Posts: 71 |
I made an easy to follow picture here, when I resize the volume bars are too thick, and they overlap onto the next number. In jigsaw there is a short and concise format to save space, it's about 1/3 as much room taken up. Thanks for your help! |
[2019-09-05 00:40:21] |
When you say the volume bars are thick, are you referring to the vertical height or the horizontal width? The horizontal width is controllable. The font size is adjustable. This is explained here: Volume By Price Study: Display Volume in Bars And in regards to order details there are new options coming out in a couple of weeks which will make all of that more controllable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 00:40:43
[2020-05-08 12:08:51] |
User16876 - Posts: 10 |
And what about the vertical height pls? Especially the vertical heights of ChartDOM's volume bars (Pulling/Stacking, Buy/Sell depth columns, etc.)? There seems to be some vertical height minimum limit and when the rows get thin(ner) they (the bars) overlap each other (see attached image pls). Is there any way how to solve this? Thank you. http://www.sierrachart.com/image.php?Image=158893917035.png |
[2020-08-13 21:34:40] |
John - SC Support - Posts: 31293 |
We have made a change to how the height of the Volume Bars in the Chart/Trade DOM are drawn, so they now will only have a minimum of 2 pixels and not the text size as they were previously. This works in the same way as the Volume by Price bars. This will be in the next Pre-Release v2152. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
