Date/Time: Thu, 02 May 2024 22:05:29 +0000
US Equities SierraChart datafeed
View Count: 690
[2019-09-04 14:30:53] |
patrader - Posts: 92 |
I am a futures trader subscribing to SierraChart's datafeed (trading via CQG FIX). Is it possible to receive and chart data from SierraChart's datafeed for U.S. Equities i.e. (NYSE, NASDAQ, AMEX, BATS), $10.50 USD / month, without having a stock trading account and without changing my Data/Trade Service settings?
[2019-09-04 14:44:22] |
Yes this is fully supported. Just activate that exchange. And then open charts for stock symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-04 14:46:28
[2020-05-22 17:00:40] |
User135370 - Posts: 160 |
Hi I use Denali with AMP and would like to chart stocks, what is the best way to do this |
[2020-05-22 18:43:45] |
SC Support - Posts: 1797 |
Hi there, you should be signing up for the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed set-up instructions: Sierra Chart Exchange Data Feed: Setup Instructions if US stocks are your focus choose: "U.S. Equities (NYSE, NASDAQ, AMEX, BATS)" Sierra Chart Exchange Data Feed: Supported Exchanges |
[2020-05-22 21:33:36] |
Thanks that’s good to know, I would actually prefer to fo direct through Sierra as I would be trading on a different options platform I don’t need to do this through AMP so I have created a new account direct with Sierra and will set it up that way. Less hassle and men in the middle.
[2020-05-24 02:00:10] |
Okay just let us know if you need more help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-24 02:00:16
