Date/Time: Mon, 20 May 2024 01:16:21 +0000
No ES data anymore
View Count: 1124
[2013-12-10 17:16:43] |
timokrates - Posts: 28 |
Hi, I'm running Sierra with IBs TWS on the latest versions. All of a sudden my ES charts do not update. I have done several things including the delete of all data and the data files themselves. What I get is some weird data basically all the same price level and then it runs into the IB pacing violation. In general, how do I get the Sierra historical data backfill up to the current point where then IB realtime takes over? Of course I read the documentations and also I'm a long time Sierra user, but it just does not seem to work. What is absolutely weird is that it tries to get data from march when the chart settings are set to load only 30 days... In general, why is also the historical sierra chart data not loading? |
[2013-12-10 17:35:51] |
Refer to help topic 3: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html What is absolutely weird is that it tries to get data from march when the chart settings are set to load only 30 days... In general, how do I get the Sierra historical data backfill up to the current point where then IB realtime takes over? https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php The Sierra Chart service provides both real-time and historical data. We have never provided integrated historical Intraday data only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 17:37:09
[2013-12-10 20:52:42] |
Ok, thanks. Works again. Don't really know what solved the problem I was working on for two days now... But how do I get the most detailed Sierra backfill up to the IB realtime data? So far I see that it only comes up to a certain time and not actually up to the point when I open the chart. Actually it is that I would demand from a backfill. Is it possible to get the backfill up to the time opening the chart, so that the historical data is solely from Sierra? If not, how much 5 second data you think is possible to get from IB untill running into the pacing violation? I have only a very limited demand here. Only one or a few days ES data. Date Time Of Last Edit: 2013-12-10 20:53:43
[2013-12-10 20:56:25] |
But how do I get the most detailed Sierra backfill up to the IB realtime data? https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php The Sierra Chart service provides both real-time and historical data. Sierra Chart has never provided integrated historical Intraday data only, to be used with Interactive Brokers. In your case, at all times historical data has always and is currently being obtained from Interactive Brokers. Never from Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 20:57:26
