Date/Time: Mon, 29 Apr 2024 21:24:08 +0000
Charts showing different prices in multi-timeframe backtest.
View Count: 595
[2019-09-04 06:11:05] |
SirGriff - Posts: 1 |
Hey, we're trying to do some backtesting with the Accurate Trading Sysstem replay, using the replay function on intraday charts which are linked. The charts are: 5m, 10r, 5r. We are jumping forward bar-by-bar on the 5r chart. The problem we are having, is that after jumping forward a few times, the prices/times are not synchronized. On /ES we get varying accuracy on quotes. It is making backtesting impossible. Sometimes it works for a little bit, with the prices being synchronized, and then goes back to being messed up. We could be jumping forward on the 5r, and seeing a move before it's happened on the 5m chart. Included a picture of the charts in question. http://www.sierrachart.com/image.php?Image=1567576943521.png |
[2019-09-05 18:45:26] |
When you jump bar by bar, and the charts have different time frames per bar, they will lose synchronization between each other. Longer term we will implement a solution for this but it does not exist at this time.
