Date/Time: Sat, 04 May 2024 21:46:26 +0000
Stops/Targets Offsets Based on Currency Value
View Count: 468
[2019-09-03 22:48:41] |
User379468 - Posts: 508 |
Possible to set Stops/Targets using Offset based in Currency value instead of Ticks? ie, instead of 20 ticks stop/target, set based on $200 stop/target. Useful to normalize for dollarized volatility across instruments. |
[2019-09-04 08:30:38] |
No, this is not supported.
[2019-09-04 12:59:39] |
Could this be implemented? Would be useful.
