Date/Time: Tue, 17 Nov 2026 16:32:23 +0000
control bar
View Count: 826
| [2019-09-03 22:17:11] |
| User895425 - Posts: 7 |
hi, I want to make my own buttons in the control bar such as different kind of lines such as dash and solid I want that with that buttons I will draw immediately a line with my own properties for that specific line do you have a video for that? thanks |
| [2019-09-04 09:42:52] |
Refer to: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
